Unistrut code evaluation report
Hi all. This question is a result of days of looking through Unistrut's extremely poor engineering literature. I am scavenging for a code evaluation report for either Unistrut or a similar product (such as Powerstrut) to help me navigate this stuff. Anything remotely close to a code evaluation report for these products? I searched on ICC but found absolutely nothing.
RE: Unistrut code evaluation report
That said, I am guessing you are looking for some more load capacities for a connection that isn't tabulated in their book? That has happened to me before, and I emailed Unistrut and asked them to provide me the capacity for the configuration I wanted. Thus far, I have had no problems getting the info I needed.
"It is imperative Cunth doesn't get his hands on those codes."
They do provide section properties so you can run calcs as needed
I think Hilti also has load tables for their components.
Unistrut engineers their lightgage products to generally conform with the AISI steel code, but their wacky proprietary perforated shapes fall outside of using the AISI to directly calculate their capacities. Hence, they load test their unique products, and provide their section capacities in the general engineering catalog. I am certain you could use the AISI code to calculate the capacities of common shapes, but why? I don't see how that is going to produce more efficient designs. Besides, if your computation resulted in an allowable bending moment 20% higher than the tabulated capacity, why would you want to stick your neck out and use the higher capacity?
Am I still missing something?
I also imagine the holes are not a huge issue as the open side likely controls much of the design.
I wouldn't go there unless I *had* to, and even then I wouldn't want to. I haven't had a crazy beam-column Unisrut yet. To me, it is much quicker and conservative to use an elliptical interaction equation with the power coefficients set to 1.0.
Awa, can you give us a sketch and loading of the frame you are designing?
I totally agree. Serviceability would probably control some of it anyway.
My situation is that I am trying to make sense of the Unistrut general engineering catalog so that I can spec bracing systems for mechanical equipment. Not a specific framing/loading situation. As a recent grad, I have no idea how to use these catalogs. There is no guidance for new users, and the only resource I found is the following (http://www.unistrut.us/E-document/Unistrut-Seismic...) with a couple of (really) crappy low quality examples. I just need something that can help me use the general engineering catalog... a sort of comprehensive "user manual" geared towards new users with structural engineering background. I know it sounds like I am trying to reinvent the wheel, and maybe I am a little bit, but I believe SOME background is helpful, if not necessary, to pull values from these tables! Anyone can pull values out of the air but an engineer is supposed to know what theyre doing at least a little bit...
No resolution on that one either.
Absolutely. Proper interpretation of those tables requires comprehensive engineering expertise. Also, the nature of tables is that their use implies that there are restrictions for how/where they are appropriate.
I completely understand. What about guidance from your supervising PE? It can be tough to guide very broad questions via an internet forum, but as XR250 mentioned, you should start getting comfortable with lightgage design per the AISI code. Most of Unistrut's components fall under light gage steel. Though, some of the plate material technically falls under structural steel.
You are writing a spec? I am surprised that as a recent grad that you are doing that, assuming that your position is that of an entry-level structural design engineer. Maybe your position is actually as a spec writer? That would make sense. Or - do you mean that you are just trying to prepare yourself for when you do have to design some bracing? I am curious what spawned that.
I ask those questions to try to maybe narrow down enough to provide some more specific guidance.
Many thanks for the advice and interest. I will follow your recommendations very closely. No, not a spec writer, I'm just preparing myself for when I'm asked to design this type of bracing....
