Determine Load carrying capacity - Ansys parameter set
Dear all,
Is it possible to use parameter set in Ansys workbench to determine the maximum load carrying capacity for a given design by limiting the stresses to a desired value. i.e, Is it possible to find the maximum load carried by a body for a given stress since Stresses or output parameters are not variable in parameter set.
Any sort of help will be of great use.
With warm regards,
Vignesh Kumar V
