Mass not found when deleting constraints
Hi everyone,
I was given an ANSYS MECHANICAL APDL model with different constraint equations.
I only need the K and M matrices so I decided to take out all the constraint equation of my model.
In order to do that, I use the GUI option --> Pre-precessor/Coupling-Ceqn/DEL Constrain equation
I have previously check the number of constraint equations and input that in deleting constrain equation (1 to number of equation).
However, when I do that it seems that I cannot get the mass of the model.
On the other hand, If I run the script with the constraint formulation seems to work fine.
Any suggestion?
Thank you,
