Analysis and Design of large mat foundations supported on soil using FEM considering soil -structure
Large mat foundations are usually modeled using plate elements and the boundary conditions at soil – foundation/structure interface is idealized using winkler springs assigned with sub-grade modulus of soil (using plate mat with compression only springs in STAADPro to establish and take into account the loss of contact, if any). Needless to say, such an analysis is non-linear in nature and time consuming as it involves several iterations spreading over the entire set of load combinations in order to obtain convergence of results in each case.
For service level load combinations, foundation sizing is carried out based on the maximum bearing pressure, stability ratios (overturning and sliding) & estimating / limiting the contact area thus obtained.
Usually, the above sized foundation is then re-analyzed using strength level load combinations to obtain bending moments & shear forces at the sections of interest, in order to design the concrete thickness and reinforcement required.
Now, the point of discussion here is, should such foundations be re-analyzed in STAADPro (or any other analysis software) using the strength level load combinations in order to obtain the design forces?
OR
Should the internal forces obtained using service level load combinations above be simply magnified with strength level load factors to arrive at the strength level design forces?
Thanks and Regards
Sunny
RE: Analysis and Design of large mat foundations supported on soil using FEM considering soil -structure
In these circumstances, when non-linear effects are explicitly considered, each load case must be analysed separately as the boundary conditions of the FEM model change with the load magnitude and distribution. In this way, service level load effects can't just be magnified by a load factor. It is the same as in the non-linear analysis of laterally loaded piles.
