Cable Mullion
Cable Mullion
Cable Mullion
What is the allowable deflection in cable? Suppose I have 8 meters long cable mullion..
RE: Cable Mullion
You're going to need to give more info regarding the application. maybe a sketch as well.
RE: Cable Mullion
For a glass facade, on the range of L/50 under 50 yr winds to prevent damage to the glass and sealants. For seciceability wind loads, it's more about not frightening the villagers.
RE: Cable Mullion
L/50? some flexible glass there!
Is this a handrail/guardrail mullion? then the answer is less than 2" ever or as per OSHA (USA?) or building code
RE: Cable Mullion
The trick is to realize that your facade will be likely be assembled from multiple lites connected to the cables near the edges of those lites. As such, cable deflection results in essentially no glass deflection but a whole lot of rotation in the sealant joints between lites.
RE: Cable Mullion
So an N-sided-agon. seems logical for that application
RE: Cable Mullion
Exactly. Of course, I'm just guessing at what I think OP might be up to.
Glass itself can tolerate a surprising amount of out of plane deflection too. L/50 would be a bit much though.
RE: Cable Mullion
Do you know in what standard I can find the L/50 deflection limit? I've also heard that there is L/75 deflection limit too
Pratama H.R.S., B.Sc, M.Sc
Facade Engineer
RE: Cable Mullion
I know of no code specifying applicable deflection limits pratamahrs. If you find one, I'd love to hear about it.
RE: Cable Mullion
The amount of pre-tensioning load to the single cable will depend on the permissible deflection of the cable. While there are no standards mentioning this allowable deflection, it is worthwhile to know if it is better to prove by testing or by theory. L/50 would be ideal but up to what span?
RE: Cable Mullion
I don't think there are, as yet anyway, standards or codes which apply to this sort of facade. You just need to be a hero.
