where can I buy a pulley to fit a 3/16'' shaft?
Where can I buy a pulley to fit a 3/16'' shaft?
The pulley I need should be around an inch in total diameter but must ft a 3/16'' shaft. The pulley should be the type of pulley with a bore, the kind that would pull a round belt. Also where might I get a round belt that would fit in the pulley and be about ten inches long?
I have been searching in vain for quite a while and would greatly appricate any information you can tell me, thank you.
RE: where can I buy a pulley to fit a 3/16'' shaft?
Or WM Berg @800-232-2374
