Heat exchanger nozzles modeling
Dear all,
I'm modeling a pipe with a heat exchanger at the end. What is the most realistic way of modeling in CII heat exchanger nozzles ?. Maybe I have to impose translational stiffness or perhaps using CMR 297 is enough. I'm discarting anchor in the nozzle because I have to suported a few inches before, and that model causes distortion in load results.
Would you be so kind to give me some recommendation on this heat exchanger nozzles modeling issue?
Best regards.
Best regards.
