Threaded hole start chamfer
Is there any way to edit the start/end chamfer of a threaded hole before or after it has been created? It seems like the option is there because once you enable the chamfer the diameter and angle are shown, but there is no way of editing these. If it is a customer default for this, I was unable to find it. Using NX 9.0.3.4 MP12
RE: Threaded hole start chamfer
ref:
https://docs.plm.automation.siemens.com/tdoc/nx/10...
