STIFFNESS ANALYSIS - ACCOUNTING SELF WEIGHT
hi, i am writing a code in fortran for static analysis of portal frames. the intention is to put some point loads on the structure and analyse it to get the reactions/displacements. could some one explain how to consider the self weight of structure in the analysis.
thanks,
RKR
RE: STIFFNESS ANALYSIS - ACCOUNTING SELF WEIGHT
Self-weight for beams would simply be calculated as a uniformly distributed load derived from the weight of the section.
If you're using a stiffness matrix algorithm, you'll likely deal with the self weight at statically equivalent nodal forces at the ends of the members.
thanks a lot
