modification new pipe
In our company we need to connect the boil off gas line to relief line.
is this modification need to vent or drain? and what is the main factors in this type of work?
Thanks for your participation.
RE: modification new pipe
my question is:
is this modification (line) required vent or drain or both?
thank you
If there is a pocket, you might want a drain. A high point pocket? Probably need a vent. Isolation valves? Might want vents and drains for maintenance. Is the line made of Tantalum? If so you might want to minimize valves.
Basically... how could anyone know with the information you provided?
