Regarding Bolt circle center line symbol in Drafting
I am facing one problem with Bolt circle center line symbol in Drafting.
When I use this symbol for pitch circle dia, it is creating full circle and not able to adjust to required length.
If anyone knows how to edit, please help me.
Ravi
Ravi
RE: Regarding Bolt circle center line symbol in Drafting
Remove check for full circle under placement in bolt circle centerline command.
Select circle in counterclockwise direction to have Bolt circle limited to selection.
Jignesh Patel
L&T Technology Services
