Sensor to Detect Air Escaping From Product
Hi all,
I'm looking for some direction on a sensor which could be used to detect air leaking out of a plastic cylindrical shaped product. The product can be pressurized so that any small holes would be emitting some type of stream of air.
I've looked into vane and hot-wire anemometers and though they seem promising I haven't found any standalone analog type sensors which would be great when used in conjunction with a PLC.
Any thoughts?
Any thoughts?
RE: Sensor to Detect Air Escaping From Product
It's unlikely that the sensors mentioned can read flow rates that correspond to "leakage"
TTFN
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
- production volume/quantity to be serviced by this test (which dictates cycle time required)
- accuracy/tolerance requirements
- response time needed
- test reliability limits (6-sigma levels, or something less...how many false readings are you willing to accept in your production stream?)
Your solution could range from a simple water tank dunk test in which the operator observes bubbles to a more sophisticated helium leak rate test.TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
Is the product normally pressurized, or are you just doing a leak check for envelope integrity?
Mike Halloran
Pembroke Pines, FL, USA
https://en.wikipedia.org/wiki/Tracer-gas_leak_test...
"You measure the size of the accomplishment by the obstacles you had to overcome to reach your goals" -- Booker T. Washington
