How to change the default name of the generated file
I want the default name of the generated file has the same name as the group. Do not name the file prt. Can I do this in postbuilder or settings nx?
RE: How to change the default name of the generated file
It's a little hard to tell exactly what you want and what window you have in the image as I can only read English. However some ideas that come to mind are to browse through the customer default settings:
File->Utilities->Customer Defaults
You might be able to find the right setting in there for a default file output.
If that doesn't work maybe there is a settings file within the Siemens Program Files Folder.
Sorry to not be of much help.
Another option is to use library output mode, where the post and shop docs output files will be organized by program name. You can try this by selecting the cam_library configuration, or adding this to your current configuration:
LIBRARY_CAM_OUTPUT,${UGII_CAM_LIBRARY_TEMPLATE_DIR}cam_output.def,${UGII_CAM_LIBRARY_TEMPLATE_DIR}cam_output.tcl
Mark Rief
NX CAM Customer Success
Siemens PLM Software
