Flaring Control Valves
Hi, I am trying to calculate how much flow goes through a control valve that ends up as flare gas. I have used data sheets to identify thy type of control valve (linear, equal % or quick opening). I need a way to relate the flow coefficient (Cv) to the opening of the valve which will tell me how much flow is in the valve. Can someone please help? I am stuck!
Apparently there are equations for each different type of valve but I can't seem to find it!
RE: Flaring Control Valves
