sign priority
sign priority
This forum's been quiet for a while. Perhaps this will liven it up...
Some authorities say that regulatory signs should get the highest priority for placement and maintenance. Others say warning signs. What do you think?
RE: sign priority
KRS Services
www.krs-services.com
RE: sign priority
RE: sign priority
RE: sign priority
RE: sign priority
1> "Immediate" signs: Intersection control (Stop, yield, crossbuck, etc), curve signs, and one way/Do not enter signs
2> School signs
3> Other regulatory signs
4> Other warning signs
5> Street name signs
6> Other guide signs
The signs in the Immediate category are top priority signs that address three of the most severe accident types: intersection, run-off-road and head on collisions. I agree with that part, but I'm not sure I agree that "other regulatory signs" should be more important than "other warning signs."
RE: sign priority
In terms of sign management and inventory, I believe emphasis on priority must always be peppered with common sense and a little crystal balling. The questions that should be asked when dealing with a sign is what would be the likely outcome if an injury or accident occurs as a result of sign absence, mis-interpretation, hidden placement or vandalism.
KRS Services
RE: sign priority
Prioritizing signs by class is also a tool. Like all tools, it must be understood to use properly. Even within a specific sign type, some will be more important than others. A "no parking" sign that keeps parked vehicles from blocking sight distance to a crosswalk would be more important than most of its kin elsewhere.
RE: sign priority
Is the basis of the priority system for inventory and maintenance purposes? I am a little unclear as to why the priority is premised on the accident types? First and foremost a non-regulatory sign has really no bearing on accidents. Even regulatory signage, really has no bearing on accidents because you cannot legislate against stupid drivers or inattention.
I am not understanding the benefit of a sign priority system (esp. non-regulatory) in relation to accident types. I've used inventory and maintenance software, but never in relation to accidents. I'm not sure whether I've just helped or confused the issue more.
KRS Services
