Good morning Friends, Is anybody
Is anybody have the idea regarding the code symbol for ERV/PVRV?
Like the PSV , ASME stamp is required for ERV/PVRV also?
ERV/PVRV which is mounted on the storage tank (As per API 650) need to be stamped with ASME/API?Set pressure is 0.08bar(ERV)&0.05bar (PVRV)
Please share your ideas.......
RE: Good morning Friends, Is anybody
Given the very low pressures, it is unlikely that this device needs any stamping at all, certainly not ASME VIII
Probably better to ask you question in the storage tank forum where API 650 issues are discussed. Also search in that forum for the answer.
