Edit an exploded view
Hi
I have an exploded view with a component exploded in a rotated position
but I forgot the rotating hinge and the rotating angle and now
I want to explode another component with the same rotation
As like I have selected them both in the original explosion
Please any help or trick ?
Thanks in advanced
RE: Edit an exploded view
USING NX8.5
Using information -> assemblies -> explosion... NX will report the explosion transforms of each component. However, it will report them in a transformation matrix style output, which isn't immediately 'human readable' as 'rotated 15° about the X axis', but it can be used to calculate such rotations.
www.nxjournaling.com
Below is a small journal that will report the rotation angles about each axis. To recreate the rotation on another component, apply the rotations in XYZ order (X first, then Y, then Z); not following the order will result in a different rotation.
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim theUfSession As UFSession = UFSession.GetUFSession()
        If IsNothing(theSession.Parts.BaseWork) Then
            'active part required
            Return
        End If
        Dim workPart As Part = theSession.Parts.Work
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Const undoMarkName As String = "report component explosion"
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName)
        Dim explosionTag As Tag = Tag.Null
        Dim explosion As Assemblies.Explosion
        theUfSession.Assem.AskViewExplosion(theSession.Parts.Display.ModelingViews.WorkView.Tag, explosionTag)
        lw.WriteLine("current work view: " & theSession.Parts.Display.ModelingViews.WorkView.Name)
        If explosionTag = Tag.Null Then
            lw.WriteLine("  no explosion associated with the current work view")
            Return
        Else
            explosion = Utilities.NXObjectManager.Get(explosionTag)
            lw.WriteLine("  explosion: " & explosion.Name)
        End If
        lw.WriteLine("")
        Dim explodedComp As Assemblies.Component = Nothing
        If SelectComponent("Select a component", explodedComp) = Selection.Response.Cancel Then
            Return
        End If
        lw.WriteLine("component: " & explodedComp.DisplayName)
        Dim explosionStatus As UFAssem.ExplStatus
        Dim explosionTransform(3, 3) As Double
        theUfSession.Assem.AskCompExplosion(explosionTag, explodedComp.Tag, explosionStatus, explosionTransform)
        lw.WriteLine("  explosion status: " & explosionStatus.ToString)
        'lw.WriteLine(explosionTransform(0, 0) & ", " & explosionTransform(0, 1) & ", " & explosionTransform(0, 2) & ", " & explosionTransform(0, 3))
        'lw.WriteLine(explosionTransform(1, 0) & ", " & explosionTransform(1, 1) & ", " & explosionTransform(1, 2) & ", " & explosionTransform(1, 3))
        'lw.WriteLine(explosionTransform(2, 0) & ", " & explosionTransform(2, 1) & ", " & explosionTransform(2, 2) & ", " & explosionTransform(2, 3))
        'lw.WriteLine(explosionTransform(3, 0) & ", " & explosionTransform(3, 1) & ", " & explosionTransform(3, 2) & ", " & explosionTransform(3, 3))
        Dim rotAngleX As Double
        Dim rotAngleY As Double
        Dim rotAngleZ As Double
        ExplodedCompRot(explosionTransform, rotAngleX, rotAngleY, rotAngleZ)
        lw.WriteLine("  rotation about X axis: " & rotAngleX.ToString)
        lw.WriteLine("  rotation about Y axis: " & rotAngleY.ToString)
        lw.WriteLine("  rotation about Z axis: " & rotAngleZ.ToString)
        lw.Close()
    End Sub
    Function SelectComponent(ByVal prompt As String, ByRef selObj As TaggedObject) As Selection.Response
        Dim theUI As UI = UI.GetUI
        Dim title As String = "Select a component"
        Dim includeFeatures As Boolean = False
        Dim keepHighlighted As Boolean = False
        Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
        Dim cursor As Point3d
        Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly
        Dim selectionMask_array(0) As Selection.MaskTriple
        With selectionMask_array(0)
            .Type = UFConstants.UF_component_type
            .Subtype = UFConstants.UF_component_subtype
        End With
        Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObject(prompt, _
         title, scope, selAction, _
         includeFeatures, keepHighlighted, selectionMask_array, _
         selobj, cursor)
        If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName Then
            Return Selection.Response.Ok
        Else
            Return Selection.Response.Cancel
        End If
    End Function
    Sub ExplodedCompRot(ByVal transformMatrix(,) As Double, ByRef RX1 As Double, ByRef RY1 As Double, ByRef RZ1 As Double)
        'extract euler angles from rotation matrix:
        'https://d3cw3dd2w32x2b.cloudfront.net/wp-content/uploads/2012/07/euler-angles.pdf
        Dim RotMat As Matrix3x3
        RotMat.Xx = transformMatrix(0, 0)
        RotMat.Xy = transformMatrix(0, 1)
        RotMat.Xz = transformMatrix(0, 2)
        RotMat.Yx = transformMatrix(1, 0)
        RotMat.Yy = transformMatrix(1, 1)
        RotMat.Yz = transformMatrix(1, 2)
        RotMat.Zx = transformMatrix(2, 0)
        RotMat.Zy = transformMatrix(2, 1)
        RotMat.Zz = transformMatrix(2, 2)
        Dim c1, c2, s1 As Double
        RX1 = Math.Atan2(RotMat.Yz, RotMat.Zz)
        c2 = Math.Sqrt(RotMat.Xx ^ 2 + RotMat.Xy ^ 2)
        RY1 = Math.Atan2(-RotMat.Xz, c2)
        s1 = Math.Sin(RX1)
        c1 = Math.Cos(RX1)
        RZ1 = Math.Atan2(s1 * RotMat.Zx - c1 * RotMat.Yx, c1 * RotMat.Yy - s1 * RotMat.Zy)
        'convert angles from radians to degrees
        RX1 *= -(180 / Math.PI)
        RY1 *= -(180 / Math.PI)
        RZ1 *= -(180 / Math.PI)
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
Hi Cowski
Thank you very much for your response
I tested your journal on an exploded view as follows
I rotated a comopnent about the Z axis 30 deg and then I moved the CSYS to some place
and then I run your journal and I got this output
current work view: xploded1
explosion: Explosion 1
component: v04_pivot_small_4
explosion status: Exploded
rotation about X axis: 0
rotation about Y axis: 0
rotation about Z axis: -30
The angle is OK but I have not the origin where the actual rotation done
The angles reference the dynamic csys that displays when you choose "move objects" option in the edit explosion command.
Ah its OK
Thank you very much
Here's a version that also reports the "absolute transform" rotations.
If you add a new instance of the chosen component at the absolute origin of the assembly file then use the 'move component' command (dynamic motion) and apply the reported rotation about the dynamic X axis, then apply the reported rotation about the dynamic Y axis, and finally apply the reported rotation about the dynamic Z axis and the resulting orientation of the newly added component will match that of the exploded component.
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module2
    Sub Main()
            Return
        End If
        lw.Open()
            Return
        Else
        End If
        lw.WriteLine("")
            Return
        End If
        'component transform w.r.t. component part ACS
        lw.WriteLine("  rotation about component X axis: " & rotAngleX.ToString)
        lw.WriteLine("  rotation about component Y axis: " & rotAngleY.ToString)
        lw.WriteLine("  rotation about component Z axis: " & rotAngleZ.ToString)
        lw.WriteLine("")
        Dim explodedCompPosition(3, 3) As Double
        'total absolute transform of the component in the given explosion.
        theUfSession.Assem.AskCompPosition(explosionTag, explodedComp.Tag, explodedCompPosition)
        Dim compRotAngleX As Double
        Dim compRotAngleY As Double
        Dim compRotAngleZ As Double
        ExplodedCompRot(explodedCompPosition, compRotAngleX, compRotAngleY, compRotAngleZ)
        lw.WriteLine("  rotation about absolute X axis: " & compRotAngleX.ToString)
        lw.WriteLine("  rotation about absolute Y axis: " & compRotAngleY.ToString)
        lw.WriteLine("  rotation about absolute Z axis: " & compRotAngleZ.ToString)
        lw.Close()
    End Sub
        End With
         selObj, cursor)
        Else
        End If
    End Function
        s1 = Math.Sin(RX1)
        c1 = Math.Cos(RX1)
    End Sub
    End Function
End Module
I'm very thank you
You do much for me
Also have a journals to learn from
