switch part tool for NX10
CNSZU,
Just sorted through an old thread (thread561-351988: Switch Part tool). Any chance you're still using your switchpart tool and have updated it to support NX10?
I installed it as instructed and got the following errors. I've been looking for this functionality and am hoping this is the solution.
RE: switch part tool for NX10
-Window position is saved
-No need to manually input journal directory
-Fixed bugs
Try it, it should work now.
NX10.0 Win8.1 64bit i7-3770K 16GB QuadroK2200
Assuming its not just my system, my only constructive comment (from strictly a never satisfied user/consumer perspective) is that the startup of the tool while it builds the selection is slow. If it was able to compile and display the selection menu more quickly, I would give it a 5 of 5 star rating rather than a 4.5.
Thanks again for your reply and helpful programming!
