Strange line on a sketch
Hello!
I'm looking for an answer about NX 9.0, I've a document with an strange line that I don´t know from where is it, my problem is when I try to convert my document to a .pdf this line are still in there and I dont't want it.
I tried in so many ways like see on the sketch and erase the line or put the lines off bye changing their colour but the lines don't go away, somebody know how can I erase this lines once and for all or how can I hide this line from my .pdf document.
Thank's in advance.
Thank's in advance.
RE: Strange line on a sketch
If you select this line, then press "Ctrl+I", what does NX say about this line ?
Can you delete the line ?
Tomas
Tim Flater
NX Designer
NX 9.0.3.4 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
This is what the NX says about one of the lines:
Information on object # 1
Owning part N:\NX\ESTANDARES\1613\SECUECNIA 10\MAQ-1613-10-00-10-TUE200(2).prt
Layer 255
Type Line
Color 6 (Yellow)
Font SOLID
Width 0.18 mm
Modified Version 149 11 dic 2014 18:01 (by user roberto.gamez)
Created Version 149 11 dic 2014 18:01 (by user roberto.gamez)
Information Units mm
Angle = 0.000000000
Length = 21.825000039
Start Point XC = 956.000000020 X = 956.000000020
YC = 0.000000000 Y = 0.000000000
ZC = 22.599999979 Z = 22.599999979
End Point XC = 934.174999981 X = 934.174999981
ZC = 22.599999967 Z = 22.599999967
Object Dependency Graph:
Line - ID 1974399
Used by:
None
The problem is when a want to erase the lines, first of all I can't selected it, the only way I can is press "Ctrl + j" and then select de lines but the only thing I can do is change their colour.
In drafting module when I do my drawing I can't erase the lines only can change the colour and when I convert to .pdf the lines stills in there.
I'll show what it is the problem...
thanks
I already did that, but the problem still in there, I uploaded a document with the problem.
I did everything, like select the line with Ctrl + J, I... Then I've been looking for all the document if it is a piece or something inside of a sketch but no.
If you can see the .pdf i think you can realized what the problem is.
thank you in advance..
Make sure the lines you don't want to see are not selected in that reference set.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
My problem was solved!
NX9 / TC10.1.2
HP Zbook15
