Regarding Intersection Line
We know that creating intersection line between two planes is not possible in NX 8.5. Is there any other option through which I can create a point or curve at an intersection of planes.
Thanks and Regards,
Isha
Thanks and Regards,
Isha
RE: Regarding Intersection Line
OR you can create line sketch on either of plane and make it co-linear constrained to other plane.
Jignesh
Other option is to use sketch on one plane and make your line co-linear to another plane.
Jignesh
What do you need your curves to be associated to? If it is the position of the Datum Planes, I suggest the following:
- Creating two planar faces that are linked to their respective Datum Planes
- Extend them to physically intersect if needed
- Create your intersection curve using these construction planes
- Hide the sheets in a Layer
You now have a curve that will move location if you move the original datum planes are moved.
Felix K. Holloway
Design Ninja | NX 9/10
www.nxprotips.com
a line has a start point and an end point. Since planes are endless you need more input to create a line.
But what you can create with full assoziavitiy is a reference line between two reference plane.
And of course you can create an intersection point, see attached screenshot.
Meinolf
look at the attached NX part file. The Datum axis is an endless assoziative intersection between the datum planes of the csys and Datum plane (1).
As I described if you need real lines with a start and an end point you need more Input then just the intersection planes oder faces.
I've projected the Point of the csys onto the planes and then connect the points with simple lines.
For other situations you maybe could try the combined projection command.
HTH
Meinolf
