NX10 flatten surface
Hi, is there a way to flatten a face/surface in NX? SolidWorks has begun to offer this feature since 2014 and makes me wonder if NX is catching up to that.
Thanks!
RE: NX10 flatten surface
Do possible in silkworms to flatten a half sphere surface?
Solidsworks
I haven't tried that, but my guess is it might not be possible since SW asks for a linear edge to keep stationary when flattening. But it easily flattens anything else that complies with this rule of thumb by meshing the surface and then rolling the mesh down.
I think no part of a sphere surface can be flatten
without tearing up the surface
and also for any concave surface
may be that possible for only simple surfaces
like con surface and the likes
It is able to do it with complex surfaces too, it allows the mesh to strech and compress in these regions. The good thing about that is that I could use it to create the flat pattern of the parasolid file I have attached in my other thread (NX10 sheet metal puzzle) since the sheet metal application in SW was unable to produce such outcome. I was hoping I could at least use the same approach with NX. But I will have to take a look a the file you have attached there before that. Thank you.
