Acoustic/Ultrasonic Lubrication Monitoring
Is anyone using the Grease Caddy from UE Systems, the Ultra-Lube from UVLM or SDT's grease gun adapter to monitor bearings while greasing them? Have you noticed any difference in lube quantities actually required or found a defect not yet picked up from vibration?
Patrick
Patrick
RE: Acoustic/Ultrasonic Lubrication Monitoring
http://www.reliability-magazine.com/ubb2000/ubb/Forum2/HTML/001039.html
http://www.reliability-magazine.com/ubb2000/ubb/Forum2/HTML/001296.html
http://www.reliabilitydirect.com/oilanalysisproducts/lub10.htm
These devices are good for determing that the bearing has been properly lubed, but will not replace vibration analysis in determining faults.
Patrick
