Shear Area (Av) for Steel I section
Hi, could someone help explain the formula Av = A – 2btf + (tw + 2r)tf
but ≥ ηhwtw. Am I correct in assuming we only use the formula Av = A – 2btf + (tw + 2r)tf if it is larger than ηhwtw
RE: Shear Area (Av) for Steel I section
Av = tw.d sounds about right.
BA
Your interpretation is correct abuh11. The larger of the two expressions for shear area is used.
