CSP & PFP Application
The Sub Contractor has blasted to SA 2.5 then applied a Intersheild 300 Primer 75 microns, Interherm 7050 @ 19mm, Chartek 1709 @ 25mm, Intertherm 990 @ 50 microns.
The problem is that all the coatings are cracking,the CSP/PFP is shearing off with a coating of the primer on the back of the CSP but also a fully intact primer in the substrate.
These panels have been lifted to be erected & stress movement may be a factor
Anybody else got any experience with such problems.
RE: CSP & PFP Application
COCOE
