NX10 sheet metal puzzle
Hi all,
I have attached a parasolid file. It was created with SolidWorks 2016 using complex side route to sheet metal because the SW sheet metal features were not advanced enough to perform this in a way that it could be flat patterned. Can anyone please try and recreate this using NX sheet metal? Please note that the part is slightly tapered.
Thanks in advance!
Thanks in advance!
RE: NX10 sheet metal puzzle
Hi Karlis
I posted a part using nx85
its not exactly but is very close to your parasolid
using sheet metal loft on 2 arcs
The middle section of the loft feature is skewed inwards. It is not tapered anymore.
Yes the skewed inwards is big if the openings points of the circles
are far from the aliged state and small if are close to the aligned state
If you need it not aligned I guess it is impossible.
This posted part is a version of the previous one but
with convert solid to sheet metal visualy I do not see
a skewed shape
extrude with draft, make line with neded angle, project it, make profile for cut-out, swept it with orientation set to face normals, subtract it... this is like 2 minutes... so what I am missing here.
http://www.eng-tips.com/viewthread.cfm?qid=290188
