help cutting parameters amada lc2415 fanuc 1500w
WOULD LIKE IF SOMEONE THE CUTTING PARAMETERS FOR AMADA laser-2415 FANUC 1500W
RE: help cutting parameters amada lc2415 fanuc 1500w
I can share with you the cutting parameters from a LCG 3015 is you want
IT'S THE SAME. I AM NEW TO WORK AND DO NOT KNOW MUCH .. WILL LIKE MUCH IF YOU CAN HELP
thanks i hope.....
Check out the post "Help with cutting parameters" it should help you.
Hi ,
Do you have any cut conditions for 4mm-5mm-6mm stainless on oxygen . I have the lc1212 1.5kw I've got up to 3mm stainless on clean cut somewhere near if you need them .thanks rob
