Anti Rotation in Nut with low torque to start with
i'm hoping to get a bit of assistance with stopping a nut from coming un-done if possible.
I have an application using a load cell which is being inserted into metal rod, and then pulled under tension. The load cell is inserted into a hole drilled in the rod and screwed in at the bottom end (loosely). The load cell has an external thread on the other end, which then has a nut placed on it and screwed down 'tight'.
my problem is that I cannot apply large amounts of torque to the load cell as it starts changing the output. But I also need it tight enough so it cannot come undone.
At the moment I have a nyloc nut on the thread (m20x1.5), I have tried using Nordlock washers but couldn't tighten the load cell up enough to get them to work.
the problem is I cannot measure how tight I am doing them up at the moment as I do not have a method of doing so.
But does anybody know of a good method of stopping a nut from coming undone when it isn't torqued up high to start with?
I cannot post drawings/images as its commercially sensitive.
thanks,
RE: Anti Rotation in Nut with low torque to start with
Use two nuts and lock them against each other.
@JBoggs: We tried that but it did not hold.
Have you tried any flavor of typical Loctite products?
Oh, and since it's easy to reference and fresh on my mind... http://www.eng-tips.com/viewthread.cfm?qid=408177 You could make something akin to the threaded clamp ring. I'm not sure if there are any off the shelf solutions for M20x1.5 but it'd be a good fix. Then you /can/ obtain the advantage of high torque/friction by tightening the 'nut'/ring in place, since the clamping bolt won't affect the load cell at all.
Use two regular hex (not nyloc) nuts and tighten them against each other.
Castle nuts could work if you don't mind putting a hole through the shaft
Adding onto byrdj's post, what about an internally threaded clamp on shaft collar? I see some available from McMaster Carr but they only carry sizes up to M16 x 2. That would allow good clamping force without damaging the threads.
Kyle
Looks like Misumi makes some that offer M20x1.5 threads. Link Only $8.47 and ships in 1 day.
Safety wiring the nut should work if you have somewhere to tie the other end of the wire off to.
