Template for opening SE files
Hi All,
When I open a Solid Edge file i would like the expressions, which I have in my template files, loaded into the new .prt file.
Is there an setting which says that when opening a SE file a certain template can be used ?
(i know there is a setting like this for .stp files)
Kind Regard,
Lars
Kind Regard,
Lars
Lars
Solid Edge
Inventor
NX10.0.3.5 native
RE: Template for opening SE files
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
(in other situations in nx it's the "Blank" option in the file new dialog)
John might shed some light on how the "Blank" option works behind the scene and if we can customize this behavior.
What you probably can do, is either import your new "SE-NX part" into your template and then do a save as in NX, or import your template into the new "SE-NX-part".
I know it's extra work, but that's what i came up with.
Tomas
