EPDM Automatic State Change on Check-in?
So we have standard configurable components. Usually the states are at Production but when adding a config we change the state to Adding New Configuration. After adding the config and check-in the file a lot of our designers forget to advance the states back to Production.
Is there an administrative setting to automatically advance an EPDM State during check-in without having to create a variable with a manual input? Or is there something that can be linked to the Adding New Configuration State? Or does this need to be completed via a custom add-in?
Todd
Todd
RE: EPDM Automatic State Change on Check-in?
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies to make the best use of these Forums?
