Boil off gas compressor
Can someone please list out some specific things that we need to take care of when doing the engineering for screw type Ethylene Boil off Gas Compressors? How would it be different from any other process gas screw compressor?
RE: Boil off gas compressor
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
Interested in reading the results of your review Divya11
How else would this compressor be different from any other process gas dry screw compressor?
David Simpson, PE
With a dry screw, would imagine you would have limited machine life as is typically seen in dry screw air compressors. A spare installed offline machine will help to maintain uptime.
