Regarding dimensions in sketch in Part Modelling in NX 8.5
In sketch, If i change my dimension, the sketch is updated but the dimension remains at the old location. Is there any way the dimension also moves with the updated sketch?
Step 1: I create a rectangle of width 30 mm from the origin at a distance of from 50 mm
Step 2: I change the dimension from 50 mm to 500 mm, the width : 30 mm still remains at the old location. It does not move with the sketch
RE: Regarding dimensions in sketch in Part Modelling in NX 8.5
That behavior has been improved in NX 11.0.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
so it means there is no other option in NX 8.5. We have to manually move all dimension?
If its a complex sketch with lots of dimension then this might be a tiresome work:(
Thanks John for the information
I suggest to nx team to do a big improvement
And do a screen proportional zooming so that
The text and arrows be nice to see in any zooming
Or when zoom to fit
rmc on sketch dimension -> Style -> Dimension (tab) -> top pull-down change arrows to automatic placement
Thanks jerry.. It helps to some extent..
Quote (a984928)
Or when zoom to fit
FYI, Siemens has already addressed this - Sketch Settings has an option for Fixed Text Height on Screen. Turning this ON will force the entire dimension to auto-adjust based on zoom scale; turning it OFF, the dimensions remain a fixed height regardless of the zoom scale.
Tim Flater
NX Designer
NX 9.0.3.4 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
