I need to mirror a part in another part in NX (non associative)
I am on NX 10.0.3.x
I have a part that is comprised of splines and studio surfaces (no solid bodies). Let's call that orig.
I need to create a new sibling part (called mirrored) that has the exact same geometry but mirrored over a plane (a datum plane perhaps).
The relationships is to be non associative and the position/orientation of orig and mirrored can be non zero/identity.
How do I go about doing this?
Thank You.
Thank You.
RE: I need to mirror a part in another part in NX (non associative)
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
We are still investigating. I don't think I tried wavelinking yet. Can you provide a step by step guide of what I need to do in order to try the wavelinking path?
Take orig, mirror using the Transform command (you'll have to define the plane or line to reference) and do a save as and name it mirror_orig.prt. Now you have 2 independent NX parts.
Tim Flater
NX Designer
NX 9.0.3.4 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
Tim Flater
NX Designer
I don think we can mirror a property of any feature with parameters ON.
Ex: If a spline has points x30 y10 z12 we cant do a mirror of it as x-30 y-10 or z-12.
With any of the ways its not possible.
However you can mirror your CYS DATUM itself for the new part. So that when assembled in assembly with Associative Origin, you will have same part positioned in orig and mirror positions.
HOPE YOU GO IT.
Let me know if it was do able..
