Geometric Properties vs Local Radius
I have found a suggestion to use the Local Radius Analysis command to replace the soon to be obsolete Geometric Properties command.
However when I try to use Local Radius Analysis I get a NX License Error.
Why would Siemens require additional licensing to use a command intended to replace a currently active command?
thread561-362364: What is the alternate for Geometric Properties command in NX8.5
RE: Geometric Properties vs Local Radius
I was nervous as well, though Local radius does work for me, it must be in my bundle.
Local radius requires a click the object to get the radius.
Geometric Properties, I can just hover over a radius or spline and it'll give me a number
As to why? to make you spend more money of course.
I've lost a few commands over the years because we didn't switch bundles.
