Minimum spacing 'S' between bolts in gusset plate analysis
RE: Minimum spacing 'S' between bolts in gusset plate analysis
6" along the gage lines.
Thanks. Can you give me reference if you have.
In the AASHTO Standard Specs go to Sections 10.16.13 And 10.24. There isn't any specific spacing limitation on gusset plates but You can follow the provisions of 10.24.
I must have misunderstood your question. I read the 6" from your drawing.
