2D centerline creation
working in NX9 drafting.
I would like to create an associated centerline between 2 holes shown in top view (see attachment).
The centerline needs to be equidistant between the 2 holes.
I have done a non associated work around creating a line in the member view between the 2 holes and change the font of the line. of course this is not associated to the model.
Any thoughts on how to create an associated centerline?
Wayne Huseby
Drafting Checker/Drafter
United Technologies Aerospace Systems
Jamestown, ND 58401
RE: 2D centerline creation
Not sure if this is what you are looking for. Click on MENU - INSERT - CENTER MARK. Make sure "Create multiple center marks" is unchecked. Just click on one hole and then the next hole and it should give what I believe you are looking for.
No that wasn't it. what I am looking for is to place the 2d centerline perpendicular to the 2 holes.
Wayne Huseby
Jamestown, ND 58401
No Out of the box functionality available for this...
If you want this to be associative your best bet would be to make the view Active sketch view and sketch the Centerline...One reference line through the centers of the hole. Place the centerline perpendicular on the midpoint
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
Thank you Ron
Did all you mentioned in the member view that you mentioned except for the sketch part which I had considered.
Wayne Huseby
Jamestown, ND 58401
