Save Drawing as PDF Macro and rev update
Hi All
I was trying to write a macro that I can save my drawing after every revision update as a pdf file, adding the rev(num) to the file name . After recording, I needed to know, how to grab that revision name that I update manually, to the file name I wanna save. Actually if possible, I wanted to do this without running a macro, but each time I would update the revision number, this could be done automatically. Is it possible ?
Any solution is appreciated
Sub main()
Set swApp = _
Application.SldWorks
Set Part = swApp.ActiveDoc
Part.ClearSelection2 True
longstatus = Part.SaveAs3("Z:\CAS1259F5\1259F5-P02-REV0.PDF", 0, 0)
End Sub
RE: Save Drawing as PDF Macro and rev update
I do "File, Save as PDF", type in Rev after file name.
Chris, CSWP
SolidWorks '16
ctophers home
SolidWorks Legion
If money's no object the Enterprise PDM program can be set up to do just what you want...
SW Professional 2015 SP 5.0
SW Electrical 2D/3D SP 5.0
64 bit
Intel Xeon X(R) CPU 3600 @ 2.80 GHz
8.0 GB of RAM
NVIDIA Quadro 2000
Is this revision come from custom property?
It is possible to develop what you are looking for but this needs to be developed as an integrated add-in which listens for property change events and exports the PDF if revision is changed. If you are developer I can give you some hints of API methods to use otherwise you might need to get this through the paid consultancy.
If exporting all drawings in a batch mode is an option for you you may take a look at this tool: https://www.youtube.com/watch?v=vXfXnoRT_zs which can export PDFs in a batch mode allowing custom naming.
Artem
Thank you Artem
yes I am the developer, yes the revision comes from the custom property. the table in the drawing section. and I think that at the moment the work is only to develop this part. to automatically save the drawing as pdf by changing revision. I do appreciate your points.
