CSDMG and CSMAXSCRT plots not giving out data.
Dear all
I'm having a slight issue producing CSDMG and CSMAXSCRT outputs. The output is not showing any data. The model I have consists of a composite panel and composite stringers attached with a cohesive layer. CSDMG and CSMAXSCRT have been selected for my output. I also have MAXS damage values specified for the cohesive elements, and hashin used for the composite parts. The cohesive elements have been tied to both surfaces. Do you have any idea why the contours are not giving me any values?
Thank you in advance.
Adonis
RE: CSDMG and CSMAXSCRT plots not giving out data.
http://129.97.46.200:2080/v6.14/books/usb/default....
You have to use *Contact, print and assign a surface to request the output (at some frequency) as a field output (or frame .. to visualize the results) or history output.
If you did that correctly, then you must select the correct output to visualize in Abaqus/Viewer.
If you made no mistakes in either of the two above, then there is no data in the ODB to report which suggests there is a modeling issue that needs to be fixed.
Are you new to this forum? If so, please read these FAQs:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
