Water pump discharge line
In a fire fighting project that I, and my coworkers are designing, we seem to have a bit of probleme at the discharge line of a water pump (Q= 1115 m3/h, P= 15 bars). As matter of fact, we had an elbow (LR) at the discharge nozzle, but when we rechecked on site restrains, we had to replace it with an other elbow (SR). My question is as follows:
- Is it acceptable to use a SR elbow at the discharge line of such pumps? if not could you explain why ?
- If it is not accpetable, could you please provide another solution
looking forward to recieving your responses
RE: Water pump discharge line
And elbow at the discharge will cause off-center loads on the impeller, shaft, bearings, and seals.
There is no orientation that would allow a straight run out of the pump? not even upward?
That's quite a large flow. I'm surprised you've had to squeeze this important pump into a small space but we have no information to use.
what I understood from your replies, is that the real problem lies in a piping stress calculation, not a pressure drop, please correct me if i am wrong
It also might impose issues back on the pump - they normally like at least 1 or 2 D straight pipe, but check the installation manual of the pump supplier to see what they recommend. Also talk to them about your situation to make sure it won't have serious consequences. they won't like it, but should say it's acceptable or not.
LittleInche, thank you for your reply, I think that's what I should do, and I will be checking the installation manual, apart from the manual, is there any Standard or handbook that could help, I am trying to get the best out of this probleme, still learning you know
http://www.eng-tips.com/viewthread.cfm?qid=406497
Especially for what is really an intermittent service, you will have no issue with pipe erosion either.
Thank you everyone
