can't find "Orient view to model"
after switch to NX9 I can't find "orient view to model". Does anyone knows where is it?
Also, when trying to redefine the sketch the model does not back up cluttering the sketch with features created later. Do I need to make the sketch current feature every time I want to edit it?
Thanks!
Thanks!
RE: can't find "Orient view to model"
but I can tell you if you enter into your Command Finder
"orient view to model" you will be able to see where it is.
The Command Finder is under your Help
Under home tab- sketch group- if you pick right bottom corner for full list of command under group.
You will find orient to Model check it to appear under sketch group.
Check attached image.
Thanks!
Jignesh
mechanicle Engineer
L&T Technology services
I had to open sketch in Sketch Environment. During direct edit of the sketch its not available (see screenshot)
No, this is a setting in the customer defaults what action you want to be "double click",
File- Utilities - Customer defaults- site/user- Modeling- General - Miscellaneous (tab)- Double click action for sketches "Edit" OR "Edit with rollback".
Tomas
