Density/Material in part navigator column
Is there a way to add the assigned material or the density of a geometry in part navigator column?
Showing the weight would also work.
I can do it in assembly navigator but not in part navigator.
I have a bunch of linked bodies and I have assigned materials or density to them.
The problem is the source data does not have assigned material or density so it defaults to UGNX default.
When there is an update my links assigned material or density defaults back to UGNX default.
I am trying to get the CG at center for a vibration fixture.
TIA!
TIA!
UGNX 9.0.2.5 MP1 - Windows 7 64bit
Productive Design Services
www.productivedesign.com
