A question....Transformer ratio ( sqrt (3)/2 ) problem.
Hello friends,
I have a question...Omicron cpc100 manual says that if you want to test of transformer ratio , you should use following calculationames.
Ratio = ( Vpri / Vsec ) * sqrt (3)/2
But I couldn't understand "sqrt (3)/2" where comes from ?
RE: A question....Transformer ratio ( sqrt (3)/2 ) problem.
To keep it simple consider a Delta:Wye, 480V to 480V isolation transformer. The transformer voltage ratio is 1:1, the secondary winding voltages are 277V
This is a winding ratio of 1:1/sqrt (3) or 1:(1/1.73)
I don't know where the last "2" in the equation comes from unless it refers to footnote #2. Hard to say without some context.
For a delta:delta or for a wye:wye transformer there will be no sqrt (3) term.
Bill
"Why not the best?"
Jimmy Carter
Bill
"Why not the best?"
Jimmy Carter
Waross and 111R thank you for your interrest.
I understand that constant( sqrt(3)/2 ) with your help...many many THANKS.
sorry for my english.
Yours
Bill
Bill
"Why not the best?"
Jimmy Carter
