Rule in CATIA V5 - odd/even number
Hi.
I need some help with Knowledge Advisor module.
I am trying to make a rule for odd-number and even-number.
Here is my way of thinking:
If X/Y = even-number - I dont know how to creat this part, the result should be Integer but I can make a "CHECK" for that
`Construction Elements\Offset_X\Offset` =0
else
`Construction Elements\Offset_X\Offset`=Y/2
I saw some function in c++, but it doesnt work for Catia, can You help me ?
"if ( integer % 2== 0 )
// if the integer when divided by 2 has no remainder then it's even.
cout << integer << " is even "
<<endl;
else
// the integer is odd"
RE: Rule in CATIA V5 - odd/even number
you can use mod function for that.
mod((x/y),2)==1) will be true if (x/y) is even
mod((x/y),2)==0) will be true if (x/y) is odd
Eric N.
Thanks a lot, it works. Here is my code, maybe it will be helpfull for somebody
If mod((X/Y),2)==1
`Construction Elements\Offset_X\Offset`=Y /2
if mod((X/Y),2)==0
`Construction Elements\Offset_X\Offset`=0*1mm
