NXOpen VB Journal How to extrude an arc
Hello to everyone,
I'm new in the NX Journaling and I'm trying to write down a code in Visual Basic language with NXOpen.
I managed to get two splines and one arc on NX10 with a journal but when I try to make an extrusion of it, I get an error.
This is a part of my actual code, where I define thw splines and the arc (after their splinebuilder and arcbuilder):
CODE -->
Dim spline_dx As NXOpen.Spline
spline_dx = studioSplineBuilderEx1.Curve()
Dim spline_sx As NXOpen.Spline
spline_sx = studioSplineBuilderEx2.Curve()
Dim arc As NXOpen.Arc
arc = associativeArcBuilder1.Commit()
Dim extrudeBuilder1 As NXOpen.Features.ExtrudeBuilder
extrudeBuilder1 = workPart.Features.CreateExtrudeBuilder(Nothing)
Dim section1 As NXOpen.Section
section1 = workPart.Sections.CreateSection(0, 0, 0)
extrudeBuilder1.Section = section1
extrudeBuilder1.AllowSelfIntersectingSection(True)
extrudeBuilder1.DistanceTolerance = linear_toll
extrudeBuilder1.Limits.StartExtend.Value.RightHandSide = "0"
extrudeBuilder1.Limits.EndExtend.Value.RightHandSide = "123.456"
section1.DistanceTolerance = linear_toll
extrudeBuilder1.Direction = direction_Z
section1.SetAllowedEntityTypes(NXOpen.Section.AllowTypes.OnlyCurves)
Dim curves1(0) As NXOpen.IBaseCurve
Dim spline1 As NXOpen.Spline = spline_dx
curves1(0) = spline1
Dim curveDumbRule1 As NXOpen.CurveDumbRule
curveDumbRule1 = workPart.ScRuleFactory.CreateRuleBaseCurveDumb(curves1)
section1.AllowSelfIntersection(True)
Dim rules1(0) As NXOpen.SelectionIntentRule
rules1(0) = curveDumbRule1
section1.AddToSection(rules1, spline1, Nothing, Nothing, origin, NXOpen.Section.Mode.Create, False)
Dim curves2(0) As NXOpen.IBaseCurve
Dim arc1 As NXOpen.Arc = arc
curves2(0) = arc1
Dim curveDumbRule2 As NXOpen.CurveDumbRule
'Here I get the issue:
curveDumbRule2 = workPart.ScRuleFactory.CreateRuleBaseCurveDumb(curves2)
Dim rules2(0) As NXOpen.SelectionIntentRule
rules2(0) = curveDumbRule2
section1.AddToSection(rules2, arc1, Nothing, Nothing, origin, NXOpen.Section.Mode.Create, False)
Dim curves3(0) As NXOpen.IBaseCurve
Dim spline2 As NXOpen.Spline = spline_sx
curves3(0) = spline2
Dim curveDumbRule3 As NXOpen.CurveDumbRule
curveDumbRule3 = workPart.ScRuleFactory.CreateRuleBaseCurveDumb(curves3)
Dim rules3(0) As NXOpen.SelectionIntentRule
rules3(0) = curveDumbRule3
section1.AddToSection(rules3, spline2, Nothing, Nothing, origin, NXOpen.Section.Mode.Create, False)
Dim feature1 As NXOpen.Features.Feature
feature1 = extrudeBuilder1.CommitFeature()
extrudeBuilder1.Destroy()
I get an error message after executing the journal on the line: "curveDumbRule2 = workPart.ScRuleFactory.CreateRuleBaseCurveDumb(curves2)"
Is there someone who can help me?
Thank you in advance!
Best regards,
kalo86
RE: NXOpen VB Journal How to extrude an arc
What is the error message?
Have you recorded a journal and compared you code to what is recorded?
Mark Rief
NX CAM Customer Success
Siemens PLM Software
Hi markrief,
My code derives from a recorded journal.
When I try to extrude a spline, it works.
The result does not change if I want to extrude 2 or more splines, all is working fine.
When I add an arc to the curve selection I get an error.
I need to figure out why I cannot add the arc to curve selection.
Best regards,
kalo86
