Divide Frame Intersection
Hello, anyone can help? I built chimney structure (maybe you know this as silo) with diameter 12 meter at bottom and 10 meter at top of chimney. At 35 meter elevation, it has a ring steel frame, i try to divide the frames that have an intersection but it's not working. Please help. Anyone knows why?
RE: Divide Frame Intersection
fattahma7,
May be you modeled yor "chimney", with Autocad, and is possible that there is an imprecition in your drawing, that means the frames that you want to divide are in different planes. Try to use a merge joints option or check your model.
Your frames aren't intersecting. Check your model. Redraw it. If its done in autocad correctly it should work too.
