Column to base plate load transfer
I have a completed model of a steel structure. I am applying lateral seismic load combinations with system overstrength to some of the columns in this structure. For design of the base plates, should I bring in the reactions from the overstrength load combinations or the regular load combinations?
RE: Column to base plate load transfer
If the columns or designed with overstrength, I would think it prudent to design the base plates that way as well.
I assume you are designing per AISC 341. Typically, the overstrength factor is used for lateral baseplates, but you should check the code to see if there are additional requirements.
