ANSYS Workbench - Beam Elements Orthotropy CS
I have been trying to figure this out on my own, but I found it very hard to have clear information on this.
I want to define orthotropic elasticity for a beam element model. However, I do not want to define the local element coordinate system one by one as I am changing the geometry often.
If I use BEAM189, and define orthotropic material properties, the material properties will be assigned to the element local coordinate system, is that correct? Or do I have have to define something else?
Thank you!
Mariana
RE: ANSYS Workbench - Beam Elements Orthotropy CS
Hi, help please
I have a problem with writing a Command of an oriented mesh with angle of 54.74°
There is a dedicated ANSYS forum over in "Engineering computer programs" here at ENG-TIPS
