NX VS DATABASE
NX VS DATABASE
NX VS DATABASE
Is this a true statement??????? Since a .prt file in NX consists of a primitive and sometimes many valued features with valued expressions, this file should be known as the Database file for the part. Working with this Database part file we then have this report to a specification drawing or a .dwg.
RE: NX VS DATABASE
All NX files, whether it's the geometric model, the Drawing or an Assembly, they all are designated as .prt files. The is no difference as far as NX is concerned, only in what the file contains and how it is used, but NOT how it is designated.
John R. Baker, P.E.
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
RE: NX VS DATABASE
There is a common confusion regarding the word "part". In several other (CAD-) systems a "part" is what NX calls a "solid body / body".
In NX the "partfile .prt" can contain multiple bodies and other types of geometry / information , in NX the definition "Part = the model" is not correct.
The NX partfile , the ".prt" can also drawings, assembly information, NC operations, sheet Metal , mechanical simulations etc etc.
Tomas
RE: NX VS DATABASE
Since no one came out and said it, I will. No, your statement is not true.
As pointed out, a .prt file can be something else which has none of what you described (a primitive and sometimes valued features with expressions). A .prt file can be NOTHING (that's picky), a single point, a datum, a CSYS, a curve, a surface (single sheet or a Body), a collection of sufaces (another Body type), a dumb solid with NO features (a Body) or a complicated 3D model with 100% associativity or parameters defining it - and that's just on the modeling side of things. You can have nothing in modeling and have an entire 2D drawing and it's still a .prt file.
Also, a .dwg has nothing to do with NX if you're meaning a file type - as pointed out already, a drawing is still a .prt file.
And finally, I don't feel that I work with a database nor have I ever encountered what I would consider a database in using UG and NX for 20+ years - I work with a 3D models which are sometimes sheet bodies and sometimes solid bodies, assemblies and drawings using CAD software.
Tim Flater
NX Designer
NX 9.0.3.4 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
RE: NX VS DATABASE
I agree .prt files are not a database.
I would say that Teamcenter is a database and .prt files can be in the database.
I would also say that Part Families can be made in a way that is similar to a database.
RE: NX VS DATABASE
It's quite common to hear people say that an object is "in the NX database" when they really mean that the object is stored in an NX .PRT file. So the confusion is understandable.
Regarding "is this a true statement" ... I don't see any statement, so I can't say whether it's true of not.
