Link ABAQUS 2016, VS2015 and Intel Fortran 2016
Hello Everyone, o tried to link ABAQUS 2016, VS2015 and Intel Fortran 2016 with windows 10 in several ways reading foruns on the internet. Unfortunately I got NOT PASS.
Someone can help me?
First I installed programs, in this sequence:
1 - Visual Studio 2015
2 - Intel Parallel Studio XE 2016 (at finish linked with VS2015)
3 - Abaqus 2016 - 6.16 HF3
Then I search por the path for the ifort.exe and ifortvars.bat, seting then on the system variables (variable path):
here is:
D:\programas\Intel Parallel Studio XE 2016\compilers_and_libraries_2016.1.146\windows\bi n\ifortvars.bat
and
D:\programas\Intel Parallel Studio XE 2016\compilers_and_libraries_2016.1.146\windows\bi n\intel64\ifort.exe
seting:
Then I search for the path to vcvarsall.bat (VS) and ipsxe-comp-vars.bat (Intel).
In the D:\programas\Abaqus\Commands\abq2016hf3.bat or in the D:\programas\Abaqus\Commands\abaqus.bat I called:
@echo off
@call ifortvars.bat intel64 vs2015
@call vcvarsall.bat x64
@call ipsxe-comp-vars.bat intel64 vs2015
ps: I already set system variables to the path D:\programas\VS 2015\VC to vcvarsall.bat and ipsxe-comp-vars.bat is in D:\programas\Intel Parallel Studio XE 2016\compilers_and_libraries_2016.1.146\windows\bi n like ifortvars.bat
Finally I run Abaqus Verify, geting not PASS. In the std_user.log we can see:
Analysis initiated from SIMULIA established products
Abaqus JOB std_user
Abaqus 3DEXPERIENCE R2016x HotFix 3
Abaqus License Manager checked out the following licenses:
Abaqus/Standard checked out 5 tokens from Flexnet server localhost.
<1019 out of 1024 licenses remain available>.
Begin Compiling Abaqus/Standard User Subroutines
5/4/2016 12:59:57 AM
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0.1.146 Build 20151021
Copyright (C) 1985-2015 Intel Corporation. All rights reserved.
End Compiling Abaqus/Standard User Subroutines
Begin Linking Abaqus/Standard User Subroutines
Abaqus Error: The Abaqus user subroutine library could not be found.
This may indicate a problem with the Abaqus installation.
Please contact your system Administrator for further assistance.
Abaqus/Analysis exited with errors
Searching for "Abaqus user subroutine library" I cannot find something apart to install. Since I already used subroutine with Abaqus 6.14, VS2013 and Intel 2012, I need to use VS2015 because Windows 10 do not install VS2013. It is good to use more recently programs.
Someone can help?
RE: Link ABAQUS 2016, VS2015 and Intel Fortran 2016
Hey!
I'm experiencing the same problem. Were you able to solve it?
