Pittings in pinion ---- Attn :carburize ( materials)
Thanks for the info.
Actually i wanted to know about pittings forming exactly on the pitch line of the pinion.Is there any relation with the material hardness. I have seen pinions where only in a very few tooth the pittings have been formed and not on all the tooth.
RE: Pittings in pinion ---- Attn :carburize ( materials)
If I understood your application correctly - on open girth gear and pinions - the geometrical differences can be very large and it is not unusual to see some teeth with no damage and others with pits.
Hardness is a direct factor in the resistance to pitting and if there were large differences between the hardness of the teeth in one area compared to another this could produce the same effect but my observations would indicate that this is less likely than geometric effects causing the pitting to occur in some areas before it appears in others.
