How to put LoadMesh into LoadDefinition (using FEMAP API)
When I use a command LM = LD.ID all created loadMeshes disappears from model tree. If I don't use this command loadMeshes puts into Other Loads (passing any Load Definition).
CODE --> VisualBasic
Sub createLoadsX(i As Integer)
	LS.Active = LS.ID
	Dim gr As Group
	Dim grID As Long
	grID = wb.Sheets(wsh).Cells(2+i, 17).Value
	Dim s As Set
	Set gr = App.feGroup
	gr.Get(grID)
	Set s = gr.List(FGR_NODE)
	Dim LM As femap.LoadMesh
	Set LM = App.feLoadMesh
	Dim LD As femap.LoadDefinition
	Set LD = App.feLoadDefinition
	LD.PutAll(3,FT_NODE,FLT_NFORCE,"")
	'LD.Active = 3
	LM.type = FLT_NFORCE
	LM.XOn = True
	LM.YOn = False
	LM.ZOn = False
	LM.x = wb.Sheets(wsh).Cells(2+i, 13).Value
	'LM.expanded = True
	'LM.setID = LS.ID
	'LM.LoadDefinitionID = 3
	s.Reset
	For j = 1 To s.Count
		s.Next()
		LM.meshID = s.CurrentID
		LM.Put(LM.NextEmptyID)
	Next
End Sub
Can you help me, please.
RE: How to put LoadMesh into LoadDefinition (using FEMAP API)
WOW! I've found a solution!
LD.PutAll(3,FT_SURF_LOAD,FT_NODE,"")
and
So, LD.loadType needs to be FT_NODE and LD.dataType = FT_SURF_LOAD. This constants will create load definition with type Force on Node,
title will be "Acceleration on Node" by default, but really this will be Force on Node.
bigglasses
Congratulation,
I had that doubt too, thanks for sharing the answer.
